NEED HELP. Data from C-185 Seplane Supplement
Unread postby Float Pilot » Thu Feb 18, 2016 4:13 pm
I need some numbers from a C-185 Seaplane Supplement.
I need the published take-off landing and take-off distances at sea level at standard temps. ( Gross weight)
Plus the Rate of climb at sea level at a standard temp at gross weight.
Alex
dragonfly@alaska.net
Re: NEED HELP. Data from C-185 Seplane Supplement
Unread postby KlausNW » Thu Feb 18, 2016 5:21 pm
You're not giving many specifications. What year and model 185, what make/model floats? If the floats are installed by an STC then what STC no. Does the aircraft have a gross weight increase STC?
If you are just looking for the 185 Floatplane Supplement go to esscoaircraft.com:
http://www.esscoaircraft.com/c-12009-cessna-185-series-owners-manual-poh-pim.aspx
The Cessna Floatplane Supplement is based on the certified float installation listed here in the Type Certificate Data Sheet (3A24):
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/8e3a2edb2c6b9c8786257ee60058a189/$FILE/3A24_Rev_40.pdf
Unread postby KlausNW » Thu Feb 18, 2016 5:51 pm
After reading your other post, I think I know what you're asking.
If you setup a Cessna 185 up right, it can perform within your parameters.
This one is not set up for STOL operations.
https://www.youtube.com/watch?v=VB5Aes2YAcw
Unread postby KlausNW » Thu Feb 18, 2016 6:01 pm
Unread postby Float Pilot » Thu Feb 18, 2016 6:12 pm
I only need the numbers from ANY model 185 from the Cessna factory Seaplane Supplement. I am only using it for comparison purposes, to prove that they really do not mean much when compared to actual performance.
You know how Cessna always put in a page with chart showing t/o distances at various temps. Usually with a couple models of EDO floats for the C-180 and C-185.
Oddly enough I saved POHs and Seaplane Supps over the years for the C-170B, 172( three models) , C-180( couple models) and C-206G, Beaver, Otter and Helio.
For some reason old Cessna factory Seaplane Supplements for C-185s are very hard to find.
Unread postby BGH » Thu Feb 18, 2016 8:13 pm
Is this what you are looking for,1969 185.
performance data 2.pdf
(478.99 KiB) Downloaded 170 times
Unread postby Float Pilot » Thu Feb 18, 2016 11:26 pm
That should work . Thanks a bunch.
Users browsing this forum: No registered users and 4 guests
